Hello,
I am also in need of a radio code. Model-Becker 1, Type-4462, serial#-Y5050752.
Would appreciate any help.
Thanks, Chris
Try 2674
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
Thanks, Chris
Try 2674
Worked! Thanks very much.
May I, too, request my radio code?
S/N  V5005590
R2896
1997 Boxter  Becker Model 210 w/CD player
eloveless
Hi
New in this forum, can you help me with CDR22 code in a 2004 996 GT3?
I can see on the tag (on the side of the CDR22) :
Model : BE6621
Serial : 15003075
Stéphane
Edited by stephafi
Hi
Model : BE6621
Serial : 15003075
Stéphane
Try 1030
Hi
Model : BE6621
Serial : 15003075
Stéphane
Try 1030
Works fine !!
Thanks a lot
Hello,
My radio is Becker 1, # 4462
serial number Y5043535.
24/99
Could you please provide the code?
thanks!
Jim
Edited by jkotelly
Hello,
I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type: BE 4462
serial: Y5043495
Thanks for your help
Benjamin
Hello,
Becker CDR 220
type: BE 4462
serial: Y5043495
Benjamin
Try 4896
Hello,
24/99
thanks!
Jim
Try 9810
Thank you so much for your quick reply. Unfortunately, this code didn't work for me :-(.
thanks again,
Jim
Hello,
24/99
thanks!
Jim
Try 9810
thanks again,
Jim
Did you follow the procedure in the Lost Radio Code FAQ?
It works better than 99% of the time when you do.
Hello,
I don't have the original manual and radio code for my wife's boxster and we just replaced the battery today.
Becker CR 220
type:    4362
serial: Y5030001
Thanks for your help!
Dave
Hello,
Becker CR 220
type:    4362
serial: Y5030001
Dave
Try 0108
Thanks very much.   That code worked perfectly, the first try.
Really appreciate your help.   I am inspired to get off my butt and list some basics that led to success  in eliminating the traditional Boxster enormous white smoke cloud effects, which i had not seen listed yet.  (right viscosity oil, and keeping the maximum oil level circa 7/8 full)
My brother just got his 2004 Boxster 2.7. After trying mine, he decided to sell his Z4 and go ahead with a Boxster. We are about to make some mod that will require to unplug the battery but as 99% of second owner, the radio code is not in the glove box. The radio is working right now. Is there a way to display the code as the radio is working or not? If not how can I find that code?
Tks for your help.
Thierry
Tks for your help.
Thierry
Start by following the instructions in the Lost Radio Code FAQ
