  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
I had just "relayed" numbers from the owner. I pulled the radio this morning. Could we get a code to try for
CDR 220
Model BE 6625
Serial No. # 2501 4030
Thanks in advance.
Regards,
tony
You should always use the method in the Lost Radio Code FAQ to get the serial number - it's pretty much fool proof.
But your can try 5081
Thank you Loren for this awesome and much needed service!
Request for a CDR-220
Model: BE 4462
Serial: 15075927
Thank you very much!
Try 7212
I have a radio I pulled working from my 1999 Boxster. I sold it to someone, not realizing it required a code to use it.
Typ:        CDR 220
Model:    BE 4462
SN:         X5023195
Can you help find the code?
I will make a donation to the site, if the correct code can be found so I can complete the sale.
Try 4574
Typ:        CDR 220
Model:    BE 4462
SN:         X5023195
Try 4574
Loren ---- Many thanks, that worked. I will make a donation to the site.
Thank you so much in advance. New user just to get this question answered.
I have a 2002 Boxster S
Becker CDR-220
Type 4362 24/99
Serial: 15030977
Becker CDR-220
Type 4362 24/99
Serial: 15030977
Try 9821
Becker CDR-220
Type 4362 24/99
Serial: 15030977
Try 9821
Worked! Thank you again
Thanks for such a quick reply. I'm installing the rear speaker kit this weekend and will need the code then. I'll reply again and let you know if 6403 worked. Thanks again for the help ... Love reading this forum :)
Need the code for my 2002 Boxster's CDR 220, please.
Becker 1
Type 4462
Serial # 15004630
Can you please help to obtain the code for a CDR210
SN# is V5006049 - Thanks!
Becker 1
Type 4462
Serial # 15004630
Try 0689
Worked! Many thanks.
