  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I had a problem with my boxster fuse box and had to unhook it, When i hooked it back up the radio was locked. Bought the car used a month ago. Any possible help with code? or do i need to take it to dealer.
Becker 1
CDR-220
Type 4462
24/99
serial Y5038107
Thanks in advance for any help
Try 6541
Thank you I will try that first thing in the morning and let you know how it turns out
The Code worked, Thank you so much for your help.
Hello! I am hoping you can help me with a radio code after a battery replacement. its a Becker 210 and i have these two version/code numbers: R2896, V5007157. its a 97 Boxster. Thanks so much!
Try 9615
Thanks for your reply.  I wasn't able to make that work. I tried a couple numbers on both sides of that as well, and all come back to the cursor flashing at the first number. I dont know exactly waht else to look for, I havent had to deal with this before. Thank you for your help thus far.
Did you follow the Lost Radio Code FAQ to get the correct serial number?
Hi, I too lost my radio code..
CR-220 Becker
serial # 15040011
Porsche boxster 2001
Type 4362
15031854
Cr-220
Lost my radio code tryed the faq didnt work :( please and thank you !
Try 6984
Ty so much it worked! appreciate it.
Looks like a great service..   New owner of used -- just found out about the radio code;  Great service if you can help:
CDR-220
Type   4462
SN:   Y5036230
CDR-220
Type   4462
SN:   Y5036230
Try 4798
CDR-220
Type   4462
SN:   Y5036230
Try 4798
Thanks!   Whenever power is lost I'll have the code at hand.  Appreciate it.
