1 hour ago, tylerpate@yahoo.com said:
Help Please! Lost radio code Becker CDR 220, BE 4462 Serial Number Y5043788. Im guessing that there are zeros in the serial number.
Thanks in advance! Trying to listen to some music today.
Try 2392
  • Like 1
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
Perfect!!!  I've got my tunes back. Took a while to clear the wait(9 codes in before you saved me) with my short commute but it sure made my day to get past this.
THANK YOU!!!   THANK YOU!!! THANK YOU!!!
Terre
I love my 993 engine tunes but 3mos after battery replace and a pin code still in a (very) safe place is driving me nuts! Please help!
CR210, Model R2095, Serial T5000272
Try 6513
Hello, i've a boxster and i lost the code for:
Type: Becker CDR 22
Model: BE 4467
Serial: X5020315
Can someone help me? Thanks
Type: Becker CDR 22
Model: BE 4467
Serial: X5020315
Try 6857
Need some help. A while back I purchased a 98 porsche boxster with cr 210. Unfortunately, I had an issue with the battery and the radio now is asking for a code.
I was able to take the radio out of the car but the tags are gone. The only number that is visible is the one stamped on the side of the radio which is: BE2182V5006551
If someone can help me that would be great! I have no documents with the car unfortunately.
Try 5278
Hello, re-installing original radio to car.
Radio CR-210
Serial # V5009013
Model # BE 2182
Thank you..!
Edited by Shibbiy
Hi, I bought a Becker radio to install in my 914, but did not get the code.
Typ: CDR 220
model: BE 4462
serial #: Y5050148
Thanks, Tom.
Typ: CDR 220
model: BE 4462
serial #: Y5050148
Thanks, Tom.
1
Try 8352
I just bought a second hand autoradio and I don't have the code, could you help me ? Thanks a lot
AUTORADIO :
Brand : becker
MODEL : cdr 22 - BE 4467
Serial: 15045529
44 minutes ago, dardams1988 said:
AUTORADIO :
Brand : becker
Serial: 15045529
6
Try 5292
