  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
52 minutes ago, Austorp said:
Thank you Loren! That did the trick. Do you know where I can find a copy of the CDR-220 and CDC-3 changer manuals?
They are pretty inexpensive from the dealer - just a few dollars as I recall.
Sorry, they cannot be posted here due to copyright laws.
Hello all....I have an 05 Boxster (base) that the battery died.  Now the radio doesn't work.  The previous owner gave me the manual...but I don't see any info about a radio code.  Please help!!  its the Bose radio system
You need to read the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Hello, I am a new member. I just bought a 2000 Boxster and the first thing my husband did is left the lights on when he moved my car into the garage and the battery died. I guess I need a code for the radio. I have a Becker 1 4462 and the S/N is X5027962. Thanks very much.
I am restoring a 1997 Boxster and do not have the radio code. Hopefully some one can help.
Becker: CR-210
Ser. #: V5006968
Try 7212
Becker: CR-210
Ser. #: V5006968
Try 7350
Hello,
After disconnecting the battery I can't find my radio code anymore.
Are you able to help please :)
Becker Mexico
Model BE 4337
Serial no: 15041909
Thanks a lot.
Best
Marie
2 hours ago, Marie Guerre said:
Hello,
Becker Mexico
Model BE 4337
Serial no: 15041909
Thanks a lot.
Best
Marie
We do not support the Becker Mexico but...
Try 0909
Hello hopefully you can help me I've tried everything, I have a 2002 boxster
-Cdr220
-Becker1
-Serial# 5014652
-Model# 24/99
Edited by Sebastboxster
-Cdr220
-Becker1
-Serial# 5014652
-Model# 24/99
1
Try 0865
