  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
CR-2200
Type 4466
Serial 15000354
Hope, the serial is correct. Others seem to have a letter in front.
19 hours ago, Boeingone said:
I have a 1998 993 and need the radio code.
It’s a
CR-210
SN V5001981
PR- vers R 3297
 Oops, made a slight mistake on the serial number of the radio. It should be V5007981.
 If you could send me the radio code for that  serial number it would be greatly appreciated.
Randy
5 hours ago, piethein said:
2002 996.2
CR-2200
Type 4466
Serial 15000354
Try 0754
Randy
Try 7264
10 hours ago, Loren said:
Try 0754
Thank you.
Just got the car, so the instant I saw that code from you, I knew what the hand written number in the option sticker was for... Doh!!!
BR,
Jussi
21 minutes ago, JH2000 said:
Could you please provide me the code to;
CDR-220
BE 4462
Serial # 15088214
Thanks in advance.
I just gave you a code for a (different) radio on Sunday... what's up?
The radio didn’t work, the face lit up but remained blank. I took it back to the place and they gave me another one.
It was a CCR instead of a CDR maybe that had something to do with it.
Edited by JH2000
Hi, i just bought a 996 turbo and the PO replaced the battery but he says when he went to hook up new battery and start the car, the radio asked for a code. The code that the book has as well as the code the dealer provides doesn't seem to work.
The unit is a Seimens/Becker PCM1 and the serial number is BE2582Y5007982
Unit model is a 2582
I will be calling Porsche corpporate or Becker corporate tomorrow but just thought i'd ask if someone on here might be able to find the code.
thanks
-evan
I had to replace the battery on my 986 and couldnt find the radio code anywhere.
Could you please provide it?
CR-22
Serial 25002294
Type 4367
24/99
Thank you so much!
thanks
-evan
You did not read the
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
