16 minutes ago, PHOLAN said:
Thank you!,
Would like to make a financial contribution. Do you have a Paypal account?
"Donate" at the top or bottom of any page. Thank you.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Done and thank!
One more question, my dealer tells me they can't get me the immobilizer code. I presume it's because they want to sell me a programmed remote for $800. I found a new one for $200. Any suggestions?
1 minute ago, PHOLAN said:
Done and thank!
A new remote requires programming with a Porsche PIWIS - sorry, there is no other way.
Get a quote from another dealer.
Hi Loren,
just replaced the battery of my 02 Boxster S and need the code for:
Becker CD-R-22
type 4467
serial 15037353
Cheers
Rog
24 minutes ago, Rogert78 said:
Hi Loren,
Becker CD-R-22
type 4467
serial 15037353
Cheers
Rog
Try 9176
15 hours ago, Loren said:
Did you follow the procedure in the Lost Radio Code FAQ to get your correct serial number?
Hi Loren, yep followed those, the screen shows 15037353 as the serial, type 4467 on a CDR-22.  I’ll try and pull the unit out to check the sticker.
Edited by Rogert78
1 minute ago, Rogert78 said:
Hi Loren, yep followed those, the screen shows 15037353 as the serial, type 4467 on a CD-R-22.  I’ll try and pull the unit out to check the sticker.
Chances are your radio was repaired by someone other than Becker and serial number was changed. In these cases I can not help you... sorry.
I hope someone can help.  I'm the second owner of my 2001 Porsche Boxster S.  I don't have the code card.
Here's my info...
Becker 1
type 4462
#150A5081
24/99
Can anyone provide me with the four digit code?
Thank you  :)
Here's my info...
Becker 1
type 4462
#150A5081
24/99
Thank you  ?
Try 9387
I  hope someone can help me as well.  I just changed the battery on  my 2002 Porsche Boxster S.  I don't have the radio code.
Here's my info...
Becker 1
type 4462
Serial #15087560
24/99
Can anyone provide me with the four digit code? Thxs
Here's my info...
Becker 1
type 4462
Serial #15087560
24/99
Try 5160
Hello,
I just changed the battery in my 2000 986. It has a Becker CDR-220
Serial Y5039859
Type  4462
I would appreciate help with the code.
Thank you
-Paul
57 minutes ago, Boxster1997 said:
Hello,
Serial Y5039859
Type  4462
Thank you
-Paul
Try 9243
1 hour ago, Thomas Choo said:
Hi Loren,
just replaced the battery of my 1996 993 Targa and need the code for:
Becker CR-210
serial V5006083
Regards,
Thomas
Try 9213
18 minutes ago, Loren said:
Try 9213
Hi Loren,
The code won't work anyway my car is a euro specification, not the USA version.
Regards,
Thomas
3 minutes ago, Thomas Choo said:
Hi Loren,
Regards,
Thomas
The USA version vs RoW version does not matter in radios codes - they are all the same.
Did you use the procedure in the Lost Radio Code FAQ to determine your correct serial number?
Yes I follow the lost radio cod and I get my serial mumber from the radio.
Thomas
If that code that I gave you does not work then - chances are your radio was repaired by someone other than Becker and serial number was changed. In these cases I can not help you... sorry.
Ok, thank you for the help.
Regards,
Thomas
No problem, thank you for trying.
rog
Hi, I hope someone can help. Any help would be appreciated.
Becker 1 CDR-220
Serial # 15007972
Let me know if you need anymore information.
Thank you!
