  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
2 hours ago, Adambrown02 said:
Hi, i have a 1996 911 Carrera, the battery died and i don't have the code.
CDR-210
Model ?
Serial# T5001484
Thanks for any help!
Try 9872
59 minutes ago, Loren said:
Then chances are that your radio was repaired by someone other than Becker. The radio serial number changes with any repair and they did not use the Becker algorithm -- so I can not help you. Sorry.
It is the original radio. Can you try W5017627 (my original post had an “S” instead of a 5 after W.
Sorry, that made no difference the program still says: 9280
I replaced the battery in my 2000 Porsche Boxster and lost my radio code.
Becker CDR22
Type: 4462
Serial #: 15075421
24/99
CD: 2081
Any assistance would be greatly appreciated.
Ron
Becker CDR22
Type: 4462
Serial #: 15075421
24/99
CD: 2081
Ron
Try 7259
  • Like 1
On 6/23/2018 at 4:33 PM, Loren said:
Becker CDR22
Type: 4462
Serial #: 15075421
24/99
CD: 2081
Ron
Try 7259
Loren,
Thank you very much!!  I asked the local Porsche dealer and he gave me two numbers...both were incorrect.  Thanks again
Ron
9 minutes ago, mrplow911 said:
Hi, I have a 1997 Boxster
CDR-210 Becker radio
The model number is: R2896
The serial number is: V5008414
Thank you!
Try 3653
I guess after I just pulled my Becker CR-22 which has all the white sticker labels blank means I'll have trouble providing serial numbers..?
Unless they're inside? What the hell!
Beers. HH
Beers. HH
Ok I sussed it....
type 4367
serial Y5021705
much obliged if the code could be founded!!
Cheers,
Harold.
17 minutes ago, Harry Hunt said:
Ok I sussed it....
type 4367
serial Y5021705
Cheers,
Harold.
Try 8523
18 minutes ago, BritishMotorsSoutheast said:
Hi, I need a radio code for an 02 Boxster s.  CDR-220.
Serial number is 15008107.  Thanks!
Try 6541
I've got a CDR-220 in a 996 911 C4 which I don't have the radio code for - had some work done on it during which the battery was disconnected. Below are the details for the radio:
Model #: 4462
Serial #: 15001649
Would really appreciate it if anyone can hook me up with the code. Thanks in advance!
Model #: 4462
Serial #: 15001649
Try 5491
Hello, I have a Boxster S Yr2000.  I can’t find the radio code cdr 220.   I have the VIN of the car, would that be enough?
thanks a lot for you help!
