16 minutes ago, Loren said:
If 9104 does not work then chances are your radio has been repaired by a 3rd party (not Becker) - in that case I can not help you. Sorry...
Thank you vey much for the effort, I got the radio of eBay from a dismantler, so I don't know if it was repaired.
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Just picked up today. 99 Carrera!! Woohoo!    CDR 210.                                              R 3297.        W5020876.          Thank you much.
Try 0835
13 minutes ago, Gabor Papp said:
Hi. I really need the code what i lost for my boxster PLEASE!!
Becker cdr 22
model be4467
serial 15038467
THANK YOU!!!!
Try 7561
  • Thanks 1
Hi Could you please help me with a lost radio code for a 2000 Porsche 996 twin turbo
VIN :WP0ZZZ99Z1S681301
Raido: CDR-32
Type: 4667
S/N : 45022228
THANKS!!
Edited by cam777
VIN:WP0ZZZ99Z1S681301
Raido: CDR-32
Type: 4667
S/N : 45022228
THANKS!!
Try 8612
  • Thanks 1
I need help with my radio code for a 2001 Boxster S
Type 4462
Serial # 15087058
CD  CDP2081
Thank you!
1 hour ago, Manny_911 said:
Evening, I'd love help with my code, Please.
02 911 C4S
CDR 220
Model BE 6625
Serial 15007997
Thanks in advance,
Manny
Try 7392
Hello,
I had to change my battery and didn't have a voltage saver and so lost my radio code.  I have a Becker CDR 220 Type 4362, Serial 15050689.  Would anyone be able to help me with the four digit unlocking code?
Thank you in advance.
1 hour ago, Michael M 986 said:
Hello,
Try 8585
2 hours ago, Ole Jensen said:
Hi, I need a code for a 996.
Type: IDIS BE 2580
serial: 15079249
Thank you!
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
