25 minutes ago, Mark T. Hill said:
Hi
I just got a new battery and was hoping in help for my radio code.
2002 Porsche 996
serial number 15007324
CDR 220
thamk you for any help
Try 8934
  • Thanks 1
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Thank you so much that radio code worked! Do you have a Venmo or a PayPal or I can tip you for that help?
Thank you - there is a "Donate" link at the top and bottom of every page.
  • Thanks 1
4 hours ago, Willow5 said:
Hi, please can you provide a code for a BE6654 radio? The serial number is 55020390 from a cayenne. Many thanks
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
20 minutes ago, Patrick Stafsnes said:
Your help would be greatly appreciate (after garage disconnected battery)
2000 Boxster
CDR 22
Type 4467
SN. Y5026843
Try 9181
Hi Loren,
Could you please help me? My radio got disconnected 😞
its a 2000 Boxter
CDR 220
type 4462
serial X5031312
Thanks so much!
3 hours ago, Catherin said:
Hi Loren,
its a 2000 Boxter
CDR 220
type 4462
serial X5031312
Thanks so much!
Try 7643
  • Thanks 1
51 minutes ago, Loren said:
Try 1023
I confirm that is the original code (I actually have the card).  After replacing the car battery, I mistakenly entered the wrong code three times.  Now it says "Wait".  I disconnected car battery again for a few minutes hoping that would reset it.  No love.  Any suggestions?
Did you read the Lost Radio Code FAQ?
Yes.  The only part that seems to apply is ...WAIT...  It has been nearly 24 hours since the battery was replaced.  12 hours since I put in the wrong code (insert grumbles here).  I even removed the face-plate for a few minutes.   If I've missed something simple, I'm willing to be schooled.
Hi. I just picked up a 2000 996  and the radio is asking for a code
its the cdr-220
i got 4462 for the model and my serial is Y5038913
Thanks so much..
PS. this is really stupid Porsche does this...
its the cdr-220
Thanks so much..
Try 3450
PS. Porsche didn't do it Becker did.
