2 hours ago, Ethan Biggs said:
Hello, need another radio code please
Becker - PCM
Model No: BE 2562
Serial No: X5008608
Thank you
Hmm... didn't read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
32 minutes ago, Scott Kerkman said:
Disconnected the battery while away for 2 months.
Need a code.
Becker CDR-220
Type 4462
SN Y5037426
Thanks much
Try 6919
On 2/20/2020 at 6:15 AM, Riegercar said:
Hi there, I lost my code. Can someone help me ?
Porsche CR-21 ( Becker )
Model : BE 2180
Serial W5010279
Many thanks
On 3/5/2020 at 6:20 AM, Loren said:
Try 8782
October 2015 I provided this to you...
I’ve got a Becker CDR-210 that I have lost my radio code.  Can u recommend next steps to find the code? My radio serial number is V5017018. Thank you
Try 1435
Just now, Steve Ryujin said:
Well, it is highly likely that this radio was repaired by someone other than Becker.
So sorry, I can not help you - only Becker or a replacement radio.
9 minutes ago, Provostmotorsports said:
I have a CDR-220 and do not have the radio code for the customer. The serial # is Y5039095, Type 4462. Thanks for any help on this
Try 5659
Could you please help with a radio code for my ‘99 911?
CDR-220
typ 4462
serial no 15062207
Thanks a lot!
Looking at it a second time it may be I15062207... the display reads: SERI 15062207
11 minutes ago, Gary Barnes said:
CDR-220
typ 4462
serial no 15062207
Thanks a lot!
Try 8454
  • Like 1
1 hour ago, martin sweeney said:
Hi Loren,
I have a CDR-22 on a 2000 Boxster S
Please can you help with the radio code?
Serial No. is Y502 1908
Type is 4467
Many thanks,
Martin.
Try 0901
Just now, Nick Fusco said:
Hi Loren,
Could you please help with a radio code for my ‘01 Boxster?
CDR-220
typ 4462
serial no Y5060703
Thank you!!
Try 8697
