I have a 1999 Boxster, my radio is a CDR-220 serial number W5009357 -
I cannot unlock the radio, it says WAIT....
Thank you.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Thank you.
Try 9432
  • Like 1
3 hours ago, Speedmob said:
CDR220 in Boxster S '01
Type 4462, Serial X5022158
I am stuck on WAIT and no code - thanks in advance!
From the Lost Radio Code FAQ...
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again."
Try this code  5468
10 hours ago, Marshall Angus said:
Hi my radio is a CDR22 Model be4467, serial number 15055723, I've no original booklet and had to change the battery, can anyone help???
Marshall
Try 4827
6 hours ago, kfitzpat9 said:
Hello, I have a Becker Radio CDR22 (BE4462 and need the radio Code.
 The serial number is Y5035778
Thank you!
Try 9851
That worked perfectly. Thanks so much!
On 3/6/2024 at 6:35 PM, Loren said:
Try 1309
Don't forget to hook up the wire (to the radio chassis) for the alarm system.
I just bought a 2002 Targa with a CDR-220 radio that isn’t working.
i cannot find any radio code in the paperwork.
what I do know is:
type: CDR 220
Model: BE 6625
Serial: 25011054
date of manufacture: 03/02
i also have a 6 CD changer connected but cannot see a model number on it without removing it.
how can I get the original radio code so I can at least test if this radio will work or not ?
thanks
