Hi
I replaced the battery in my 966 today, and have lost the radio code. I hope you can help me...!
Its a Becker CDR-22
Model BE6621
S/n 25006215
Many thanks is advance
james
Try 4668
or
4666
Loren
thanks, but neither of those codes worked...
I ran through the TP button down procedure and the displays shows Type 4467 if thats any use...
thanks
james
Sorry, then you will need to contact your dealer or Becker.
I managed to get the code 4768 from another forum which works! Thanks for all your help.
james
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Greetings all....new member here! I'm glad I found this forum!
Same problem....lost radio code after some paint work on my 2000 996.
Becker 01 CDR 220
Type 4462
S/N Y5043840.
Any help will be much appreciated!
Lou
Edited by couturel
Becker 01 CDR 220
Type 4462
S/N Y5043840.
Lou
Try 6391
or
6389
Sorry, Newbie here. I've lost my code as well.
I know I have a CDR 220 (in a 00 996), but how do I find the serial number/info that others are posting here?
I know this is a long thread but "how to display your serial number" is covered here... please have a read.
Very sorry. I must have missed that the first time I read through. Thanks for your patience with me.
Here's my info:
2000 996 CDR-220
TYPE: 4462
SER: X5036553
CD: CDP2081
Here's my info:
2000 996 CDR-220
TYPE: 4462
SER: X5036553
CD: CDP2081
Try 5292
or
5290
Here's my info:
2000 996 CDR-220
TYPE: 4462
SER: X5036553
CD: CDP2081
Try 5292
or
5290
Neither code worked. Now I have "WAIT", which I read above means wait 1 hour.
Any ideas on additional codes to try?
You can go the original number (5292) and add or subject by 2. Sometimes that works - sometimes you have to contact a dealer or Becker.
5294 worked!
<bows to Loren, the Porsche god!>
Loren,
Please help! In italy with no code!
type: 4462
SN: y5051420
James
Try 4674 or 4672
Loren,
No go. Worth trying 4676? May be dealer time. Thanks - James
You can go the original number (4674) and add or subject by 2. Sometimes that works - sometimes you have to contact a dealer or Becker.
Loren,
Thanks in advance for your generous assistance. I'm a 2nd owner of a '99 986. The radio fuse blew and now I need to enter the radio code, which I don't have. Can you do your magic?
1999 986
CDR 220
4462
Radio Serial Number: W5009012
Thanks.
Loren,
1999 986
CDR 220
4462
Thanks.
Try 7825
or 7823
Loren,
type: 4462
SN: y5051420
James
Try 4674 or 4672
Loren,
No luck yet. I've also tried several others mentioned here. Any other suggestions?
Many thanks,
Lou
Becker 01 CDR 220
Type 4462
S/N Y5043840.
Lou
Try 6391
or
6389
Cold weather got the best of my battery. Any help would be greatly appreciated.
2000 Boxster S
Becker 1
Type: 4462
Serial:X5031570
Try 0275
or 0273
Time for a new battery and no code with the car
2002
Boxster 2.7
Tip
Black
US
Make: CDR220
Model: BE 6625
Serial: 15008570
Edited by Kazee
