ok I finaly found the serio for my stereo cdr210 yeah ok here its (V5015733) if any one has the code for this radio please help thanks for any help
Try 4907
or
4905
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Try 4907
or
4905
thank you very much Loren the code 4907 work like a charm thanks again
Just bought a 2000 Boxster and didn't come with the owner's manual, so hence... no radio code. Can I get a preemptive strike on the radio code?
Becker Type 4362
Serial #: X5017969
Becker Type 4362
Serial #: X5017969
Try 7167
or
7165
Please help with radio code. Dead battery.
2002 Boxster with Bose Sound system and CD changer.
Type: CCR220
Model No: BE 6624
Serial No: 15002246
Type: CCR220
Model No: BE 6624
Serial No: 15002246
Try 2340
or
2338
Hi there,
I need help with radio code too. My fuse is blown and now the radio is asking for Passcode.
2000 Boxster S
Radio Type: CDR-220
Model #: BE4462
Serial #: Y5044275
Help please...
Hady
Hi there,
2000 Boxster S
Radio Type: CDR-220
Model #: BE4462
Serial #: Y5044275
Help please...
Hady
Try 9112
or
9110
Hi there,
2000 Boxster S
Radio Type: CDR-220
Model #: BE4462
Serial #: Y5044275
Help please...
Hady
Try 9112
or
9110
Thanks Loren. It appears I am the unlucky 5% also. I treid 9108, 9114, 9116, but no luck. Any other pointers?
I am the third owner of my car and I have 99% of the paperwork for my car but No Radio code :( SO Had some work done on my car this winter, installed a LWF, new RS clutch and replaced the battery and bingo I need a radio code--
Here are all my specs
1997 US
993 Carrera 2
CDR-210 with 6 cdchanger
(These are the readouts I got from the radio the hold 0 + 8 )
PR-Vers R 2896
Serial # v5010439
Thanks for your help!!!!!
1997 US
993 Carrera 2
PR-Vers R 2896
Serial # v5010439
Try 5016
or
5014
Please help with radio code. Becker 1, Type 4462, Serial 15001759.
Try 2539
or
2537
I tried those two codes as well as 2533, 2535, 2538, 2541, all no luck.
I actually have a 996, not a 986. But I don't think it should matter.
I will try a few more combinations tomorrow night (three wrong inputs and I have to wait an hour before I can try another three times), but I might be in the unlucky 5% where the program doesn't work :(
Thanks anyway! :renntech:
tried 2543, 2545, and then 2540 worked. Thanks!
I disconnected my battery and don't have the code to reset my radio. Can you help?
Becker 1
4462
Ser# 15087099
24/99
Thanks.
Gorman
Try 5565
or
5563
Yet another second owner with no Radio Code!! Any help would be most appreciated!!
2002
CDR-220
Becker
Type 4462
Ser # 25015173
Thanks!!
Try 0938
or
0936
Hi Loren, thanks for your help this must eat allot of time up! It's appreciated!
Becker cr 220
Type 4362
Y5022427
2000 boxter ser wpoca2985yu628395
Becker cr 220
Type 4362
Y5022427
Try 0956
or
0954
Thank you , Now I understand ,,, I have a cdr220 . model number off of lcd screen says 4462 witha serial number of 15001946. 24/99
the serail numbers on the radio tag is the same as above but the model number on the becker tag says BE 6625 27/01
Please help
Mike
Please help
Mike
Try 4787
or
4785
