  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren.
I have a 1999 Boxster and need the radio code. (replaced battery)
Becker CDR 210
Model# 3297
S/N W5023174
Thanks in advance, really appreciate your help!!!! :)
-Theo
Try 4406
or
4404
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hey Loren, thanks for getting back to me so fast. I tried the codes you suggested and unfortunetly they didnt work. I read on your FAQ that sometimes you might have to try two digit interval numbers.
Should I try: 4402, 4400 & 4408, 4410???
Also, after you input your code your supposed to press "UP" on the tuner correct?? The thing that changes the station and also the cd track on the right side of the head unit. (not the volume control on the left side) <------ correct me if Im wrong.
Thanks for your help....and sorry for all the questions!!!! :cheers: :cheers:
Hi Loren.
Becker CDR 210
Model# 3297
S/N W5023174
-Theo
Try 4406
or
4404
Yes, try two digits in either direction.
If the code is correct you don't press anything - after the fourth digit it starts working.
Hi there,
Aonther owner request for a lost code...
1999 C4
CDR22
Becker 4467
S/n Y5028998
Any help is appreciated...
Cheers
Neil
Try 7713
or
7711
Hi Loren,
Thanks for the codes however I did not have any luck with them.
I tried 7709, 7711,7713, 7715, 7717and 7719. Currently wainting for my hour to pass to try again.
Any other suggestions appreciated?
Thanks and best regards
McBee
Hi there,
1999 C4
CDR22
Becker 4467
S/n Y5028998
Cheers
Neil
Try 7713
or
7711
Hi Loren,
McBee
On my radio, becker cdr-220 I found that if you turn your radio off then on after two attempts it will let you try two more as long as you dont try and fail on the third attempt. When the radio turns on it will only display wait message for about a minute and then will allow you to enter the code. Hope this helps on that hour wait. :lightbulb:
My radio type is 4462. The serial # is y5047555. Please help with code.
I don't have the radio codes to my 2001 Porsche Boxster, but I have the type 4462 and the serial number Y5047555. I read the FAQ and the wait sign has disappeard. Just need help with the code. Thanks for the help!
Try 5118
or
5116
Hi
Just became a member of this great site.
Thanks in advance.
I have a cdr-220
Type 4462
Ser. Y5038593
Thank you , thank you :)
Sam
OOps sorry i did not add to the post above.
Thank you
2000 Boxster
2.7 5 speed USA
I unplugged my radio for some wiring work but have to radio code to put it back.
2002 Boxster 2.7L
Artic Silver
CDR 220
model #: BE6625
serial #: 15000733
Try 5650
or
5648
i guess im slow or something all i want to do is get a code for my radio. i dont know what the end of the faq means or how to do that
agin i must be missing somethin here
please
cdr220
4462
y5034920
Try 5650
or
5648
please
cdr220
4462
y5034920
"Neither of the suggested numbers worked - what do I do now?
My program does not always work. It works maybe 95% of the time but I have no explanation why it doesn't always work.
You can try 2 digits different each time (and sometime that works). So if your code is 1013 - then try codes 2 digits different from that code (i.e. 1011, 1009, 1015, 1017. etc.)
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers do too."
