  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Thank you Loren
I have try, but no luck!
I have buy a new radio on e-bay, to have the face plate. Is you think it's probably the reason for the code dont work? Maybe i have to change the radio?
Thank you!
Pat
CdR-220
Type: 4462
Serial #: y5060283
Thank's !
Pat
Try 6600
or
6598
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Did you read the FAQ?
Did you follow the instructions to have the radio show the serial number on the display?
Is that the serial number that you posted?
Thank you Loren
Thank you!
Pat
CdR-220
Type: 4462
Serial #: y5060283
Thank's !
Pat
Try 6600
or
6598
Thank's again Loren
For other that can help. I have try a large band of code from 6586 to 6610 with no luck.(my code was 6600) Have change the radio (got it from ebay) and that's it! Seem to change only the f face plate don't work. Other thing, if you don't want to be stuck 60 min. pull out the key after 2 try of code.
Pat
CDR 220
Type: 4462
Serial: 15064891
Try 7113 or 7111
Just back from my mechanic, and those codes did not work. I double-checked the serial number, etc. They also got a code from the dealer (2198) that didn't work either, and the one in the ECM (7168) also didn't work. Any ideas, or do I need to call Becker?
If you used the method in the FAQ to display the actual serial number and my guesses did not work - then you will need to call (and pay) Becker.
Sorry.
In case it helps refine your algorithm, I called (and paid) Becker, and got a working code: 7124.
You provide a great service here for everyone, even if it didn't work this once. Thanks!
ok lost my code heres the info
type 4462
15064965
hopefully you can get me the code and save a trip to the dealer
thanks in advance
Hey there.... I'm a newbee that needs some help.... I am working on a porsche for a customer (replacing the battery) and need the code for the deck.
Type CR210
Ser T5001968
Mod BE2182
Thanks if you can help, and judging by the track record.... You can....
Jesse
Dear Loren,
Dead battery (Boxster 2000), need code. Thanks a million in advance!
Becker CDR 220
type: 4462
ser: X5029756
:renntech:
(I hope I posted this correctly)
Edited by oki
Type CR210
Ser T5001968
Mod BE2182
Jesse
Try 4963
or
4961
post-40021-1254053510_thumb.jpgLoren,
Can you help?
Becker 1
TYPE 4462
S/N: X5018607
By the way. The picture you posted on PCA is now my computer background. Do you still have that Porsche? Mine is a 1999 MKI same color, factory Aero.
Thanks Loren
Can you help?
Becker 1
TYPE 4462
S/N: X5018607
Thanks Loren
Try 5848
or
5846
Yes, I still have my 99 Arctic Silver Carrera.
