  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi The mechanics disconnected the battery and the radio code message was prompted.
Would appreciate if you can help:-
Becker 1
CDR22
Type 4467
Serial 15004130
Thanks a lot in Advance.
Rds
Andrew
Sorry I was not clearer.
What I meant was is there anyway to have the radio display it's code before it's deactivated by disconnecting the battery?
Radio is working fine right now but will deactivate once I disconnect the battery to install a new ignition switch.
Bill
Bill
The procedure is the same before or after battery disconnect. See the instructions in the FAQ.
No radio code..
Becker CR-220, type 4462, X5023685, Thanks!
Try 4399
or
4397
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hi again
Thank you for your suggestions but the codes did not work for my radio. I have tried +-2 several times with no success.
Would appreciate if you have ideas?
einesv996
No radio code..
Try 4399
or
4397
Hi again
einesv996
PLEASE read the FAQ.
I have a 1999 Boxter 2.5 and replaced battery and now cannot locate the unlock code.
CR-220
Becker 1
Type 4362
SN: X5013228
Thanks in advacned!
I have 2002 Porsche Boxster
CDR 220, Type BE 6625, SERIAL# 25014252
Dealer gave me code of 4716 but doesnt work.
PLEASE help me I would greatly appreciate it!
Thank you for your help!
Edited by TiffanyWallace
CR-220
Becker 1
Type 4362
SN: X5013228
Thanks in advacned!
Try 8422
or
8420
Thanks Loren, the code(s) didnt work. Will try more when the radio resets. Thanks for your time.
I don't have a radio code. Can you help me?
Becker CDR-220, type 4462, W5005555,
Edited by kyny
