  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi there. Same story of the disconnected battery...would truly appreciate your help:
Thank you.
CDR 210
R 3297
W5022032
Hello,
Another request, please help.
CDR 220 BE6625
S/N 15006013
VIN WPOCA29932S65xxxx
Thank You very much in advance.
Edited by Loren
removed VIN from post
Neither worked for me. I tried the following numbers:
9669
9671
9673
9675
9677
9679
9681
Should I continue trying numbers? Is it possible to be an even number?
Thank you.
9669
9671
9673
9675
9677
9679
9681
Thank you.
Yes, you can try even numbers or your dealer or Becker.
I assume you got the serial number using the method in the FAQ?
Loran,
HELP!
Can you give the code for my radio
4462
X5018607
48/98
Thanks in advance.
