  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
CDR 220
Ser # 15050187
Radio code 7108
I don't feel the above code is correct as i have to enter it 3 times, and then it goes into wait mode, and then resets back to wanting the code.
what is odd is i have the factory radio code card and t says the SN # is BE 4462 Y 5037949 which is different from the above, when i hold the TP button in.
Thanks for the help in advance.
The radio serial number the unit displays is the correct radio serial number. Likely your radio was replaced and they kept the old card.
Try 8764
thanks so much for your assistance, that resolved the issue
Hi, I need the code for my stereo:
1997 Boxster (986)
CR-210
Serial: V5004205
Cheers!
Try 4968
That did it. Thanks so much, you rock!
Would greatly appreciate help getting a radio code for PCM. Have a 1999 996 purchased 14 months ago. Radio is BE 2582. Serial #: Y5008416. Many thanks!
Try 3569
Hi Loren
I've just had some major repair work done (see my thread 'Transmission bust I think' - I've tried to be as desciptive of the problem as someone as technically absent as myself!)
Anyway, Radio code is needed!
CDR210 (1997 - Boxster)
Serial Number V5007961
Thanks in advance!
Andy
Hi Loren
Thanks in advance!
Andy
Try 7104
Hi Loren
Thanks in advance!
Andy
Try 7104
Genius Loren - worked first time! Thanks a million.
HI, I would be forever grateful if you could provide me the code for the following radio:
PCM
2001 996 C2
Model: BE 2582
Serial #: Y5007559
Thanks in advance.
PCM
2001 996 C2
Model: BE 2582
Serial #: Y5007559
Thanks in advance.
Sorry, only the Porsche dealership can provide codes for the PCM
Refer to
Hello,
Just picked up a 2001 996 Carrera 2 but it needs the radio code. Could someone please help me?
It's a Becker CR22
Model is 4367
Serial # of the radio is 15000447
Thanks in advance!
Hello,
It's a Becker CR22
Model is 4367
Thanks in advance!
Try 5082
Hello,
It's a Becker CR22
Model is 4367
Thanks in advance!
Try 5082
It worked! Thank you very much for your help.
With kind regards,
Dennis
