  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
I have also lost the card with the code; and per your request.....
2000 Boxster
Becker 4462
Y5034525
Thanks in advance!!!!!!!!!!!!!!!!!!!!!!
2000 Boxster
Becker 4462
Y5034525
Try 5450
Hi Loren:
Please help! lost code 220 model BE 6624
serial 15001954
alan
Edited by alanln
Wow!
4 minutes and I have an answer?!
Pretty impressive. Thank you.
Loren,
Can you help please?
2002 Boxster S
Type: 4462
Serial: 15001158
Thanks in advance
Try 8242
Just bought a 99 Boxster that sat for a little over a year and need the radio code.
CDR-220
S/N X5023652
Type 4462
Thanks in advance
CDR-220
S/N X5023652
Type 4462
Thanks in advance
Try 4135
0920 doesn't work.
Any suggestions?
Thanks.
97 986
CR 210
Did you read the FAQ?
If you got the serial number through that procedure then it should work.
Hi, just picked up my new (to me at least) 98 Boxster, and the radio was locked
Here is the info
Cr-210
Becker
R 2095
T5002435
Thanks in advance!
Here is the info
Cr-210
Becker
R 2095
T5002435
Thanks in advance!
Try 4606
Here is the info
Cr-210
Becker
R 2095
T5002435
Thanks in advance!
Try 4606
No, didn't work. I just type it in and let it sit right? There's not an enter or anything
Here is the info
Cr-210
Becker
R 2095
T5002435
Thanks in advance!
Try 4606
Did you read the Lost Radio Code FAQ?
Here is the info
Cr-210
Becker
R 2095
T5002435
Thanks in advance!
Try 4606
Yes, that's how I retrieved that information. Maybe I was off a number or something?
