  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Sorry if I wasn't clear - I don't have the radio code (I'm not the first owner), and I want to have it on hand before I attempt installation of an iPod cable.
--scott
Anyone still watching this topic? I have a 2002 Boxster base. The radio (CDR-220) works fine, but I'd like to attach an aux/iPod cable and the instructions say to disconnect the power to the head unit during installation. The menu reports serial number 25014726.
--scott
Please post your question in the appropriate forum - this thread is for Lost Radio codes only.
--scott
--scott
Yes, I understand - we can not get your radio code without your radio serial number - please read the FAQ as requested.
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
It has been saying "wait" for a day. Anyway to hack into it to put the code in while it is in "wait" mode
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
Did you read the FAQ? I think not...
"I get a WAIT in the display - what do I do?
You have to wait 1 hour - with the radio on and ignition switch on (or the car running)."
Your code should be 1321
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
Thanks, I'll turn the ignition on and give it a shot.
I read the instructions, but don't see a FAQ and don't know where it would be first day on this forum.
2000 Boxter 2.7
5 Speed
Beige
USA
CDR 220
Type: 4462
Serial: Y5039751
24/99
Lost Radio Code - FAQ
CDR-220
Type 4462
Serial 25014726 (Z50147526? It looks like a 2 on the display, and I haven't pulled the radio to check the back)
CDR-220
Type 4462
Please read the Lost Radio Code FAQ for how to double check the serial number through the display.
If you think you read it correctly then
Try 1304
Im hoping someone can help, I don't have the code
CR-220
CDC-3
Y1060480
Matt
Please use the Lost Radio Code FAQ to obtain the correct serial number.
If you did and the number listed above is correct then try 8930
2001 Boxster
CDR 220
Model # BE 4462
Serial # 15088358
Many thanks; your time is greatly appreciated.
Jäger
2001 Boxster
CDR 220
Model # BE 4462
Serial # 15088358
Jäger
Try 9520
Thanks Loren that was a good code.
I have a 2001 Boxster with over 219,000 miles on it. I have owned the car since 2005 and perform most of the maintenance myself, this was the first time I have disconnected the battery. Thanks again.
Jäger
