I would appreciate it if you could send me the radio code for the s/n below.
model: 4362
s/n Y5023924
Thank you!!!
Edited by 996C2Coupe
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
model: 4362
s/n Y5023924
Thank you!!!
Try 0649
It worked! Thanks so much, Loren! You made my day
Hello Loren,
Hoping you could run your magic on below for my radio as well.
(donation on its way)
type 4362
s/n 5017208
I would appreciate any help in resetting my 2002 911 radio/nav code
There are three numbers on the radio/nav system:
- P08160013168/01--this is a Porsche tag
- 2582FB015009700 --bar code
-15009700 Model BE2582
It appears i need a code for the radio and a code for the nav
Thanks very much
John
Thanks very much
John
Please read the Lost Radio Code FAQ here
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM's require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
I don't know if this list is still active but I have a 1999 Boxster with a locked Becker radio. Can someone please get me the code?
Cdr-220
Type- 4462
Ser- W5011538
45/99
Now that I finally got to the end clearly it's still active. I'd appreciate any help I could get unloading this radio. Thanks. Original manual is long gone.
Cdr-220
Type- 4462
Ser- W5011538
45/99
Try 1019
I'm adding the rear speaker kit and the instructions said I would need the radio code after disconnecting the battery. Here is my info:
type: CDR - 220
model: BE 4462
Serial #:Y5044624
Aarron
type: CDR - 220
model: BE 4462
Serial #:Y5044624
Aarron
Try 0641
Hello Loren,
Hope you can help me. Radio got disconnected and I bought the car without the owners manual and radio code.
Following the instructions you posted, I got;
Type 4462
Cdp2081
ser 1 y5034494
24/99
Mike
Hello Loren,
Type 4462
Cdp2081
ser 1 y5034494
24/99
Mike
Try 5202
