Hi
I have just got a Boxster 1998 and, yep you guessed in no radio code.
I have removed the radio out and the sticker from the side stating the details everyone else is listing is missing.
The 14 digit reference number is engraved but, no one else is using that is there any other way of acquiring the information.
I am new to the site so I'm sorry if this question has been answered in the previous 289 pages.
Any help would be great thanks.
The model is a CDR-21.
Thanks.
Start here.... Lost Radio Code FAQ
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Thanks tried that and seven odd numbers up and down didn't work any other suggestions? Thanks in advance
Second try pressed TP after n voila!!! Worked thanks! Now I have no volume.
Thanks for your reply Loren, excuse me for sounding daft but the cdr-21 is not listed in the FAQ as a possible radio for the code or not. Please could you give me a little further direction please?
CR-11, CR21, CR-31 and CDR-21 are all numbers used is various parts of the world (other than North America). Other than wavebands the radios are the same.
CDR-21 is that same as CDR-210.
Lost the code and had to change the battery - please help. On a trip, and not having a radio is hurting! It's a CDR-220, and the serial number from the display is 25015588. Thanks!
Loren
I have 2000 C2 Cab with CDR 220; model # BE 4362 and Serial #X5018936. Need radio code.
Thanks in advance!
steve
Try 9348
Hello, i need the code, (after running out of battery) to my traffic pro model BE4760, serial nr Y5007311.
Regards Karl-ove
Regards Karl-ove
For traffic pro with 6 preset buttons...
Try 62231
Regards Karl-ove
Try 62231
Thanks, the code was right!!
Karl-ove
Try 9348
Worked! Thanks!!
Loren:
I replaced the battery and need the radio code, I purchased the car used and do not have the code.
Looking for the radio code for the following:
CDR-220
Type - 4462
Ser# 15088348
Thanks in advance
Tony
Loren:
CDR-220
Type - 4462
Ser# 15088348
Thanks in advance
Tony
Try 9540
Loren:
CDR-220
Type - 4462
Ser# 15088348
Thanks in advance
Tony
Try 9540
That worked
T
I am trying to avoid an issue of loosing my radio code.
I have a Becker CR 220, Type 4362, SER# 15031934. What is the code so I can keep this working?
Thank you in advance.
Thom
Thom
Try 4693
Hello. My Boxster didn't come with any manuals or radio codes. I had to unhook the battery to replace the window regulator, now I need a code for my radio. Thank you for your help!
CDR-220
Type 4363
Serial # 15002062
24/99
Thank you!
CDR-220
Type 4363
Serial # 15002062
24/99
Thank you!
Try 0216
