  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Not sure if I post this here or not, but worth a try. Lost Radio Code, Boxster. Becker unit CDR 220
Ser no: 15063355
Thanks in advance.
Tom
Ser no: 15063355
Thanks in advance.
Tom
Try 7607
I've got the CDR 220.
I have the radio code card.
The serial number on the card = the serial number on the radio.
I punch in the code.
Nada. Any ideas? Thanks.
Please read the Lost Radio Code FAQ -
Your radio has likely been changed out and the new card lost.
The FAQ will tell you how to get the serial number through the display on the radio.
Thanks for your rapid reply!
I used the process in the faq (Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.)
The serial number on the radio display = the serial number on the card.
I get the 4 *'s.
I type in the code as instructed.
And it doesn't work.
I have searched the internet and no one else seems to have this problem.
I get the 4 *'s.
It should be 4910. Never seen one that did not work.
Hi Loren
Just bought a 996 -99, that didnt come with any manuals:(
I would really preciate if you could help me find the code for my radio
CR-2200
Becker 1
4466
x5010038
47/98
Thanks in advance
Johan
Hi Loren
CR-2200
Becker 1
4466
x5010038
47/98
Thanks in advance
Johan
Try 0304
Same problem as so many others. My 1999 Boxster had dead battery, I changed it, and radio won't work without code. Radio is CR 220 Type 4362 ser # X5013767. Can anyone help?
