  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Just put my original radio back in car I purchased used and of course no code. Any help would be much appreciated
Becker
Type CCR 220
Model no. BE 6624
Serial no. 25005610
Just put my original radio back in car I purchased used and of course no code. Any help would be much appreciatedBeckerType CCR 220Model no. BE 6624Serial no. 25005610Thanks
Try 9524
Hello!
Can somebody help in radio code?
Becker
Typ: IDIS
Model-No.: BE 2580
Serial-No.: x5011775
65 31 35.20.12
Siemens:
MLFB: 5WK 78000A
Serial No.: PO80000155232/09
Porsche original number:
996.642.104.03 EFR
Thank You!
Hello!
Becker
Typ: IDIS
Model-No.: BE 2580
65 31 35.20.12
Siemens:
MLFB: 5WK 78000A
996.642.104.03 EFR
Thank You!
Please read the Lost Radio Code FAQ -
"These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
Yes, but dealer says, that's not the original radio in the car, so they can't give me the good radio and psm code. What's the next?
Hello!
Becker
Typ: IDIS
Model-No.: BE 2580
65 31 35.20.12
Siemens:
MLFB: 5WK 78000A
996.642.104.03 EFR
Thank You!
Hi. I have just compleated a rebuilding a damage Porsche Boxster 1997 ( used 6 mnts) imported from USA to Norway.
I did not receive any paper on this car,so I do not have the code on the RADIO. That is an BECKER CDR 210 -- MOD 2282
Serial Nr. V 5007781 Porsche nr 993 645 120 01
Can someone help me out with this please. :king:
Many thanks in advantage...
Edited by rohtpor
Try 4921
Try 4921
This was perfect, many thanks.. :clapping:
Yet here another, I bought my 01 Boxster S used. I had to replace the battery, no code.
Becker1
model 4462
sn 15063141
Thanks, so much.
Try 4142
Hi Loren
Changed battery and got locked out.
Radio is CDR 220
4462
Ser is X5036708
Thanks in advance.
Sean
Hello guys. I am planning to remove my cdr 22 because I want to connect AUX cable.
I don't have my Radio Code if something goes wrong. Can someone provide me a Unlock Code for:
Radio CDR 22
4467
Ser.: 15004504
Thanks!! P.S. I am really glad that I found this forum, a lot of interesting stuff! See ya around! :)
