Hi Loren,
New owner of an 02 Boxster planning a Window Regulator change and will need my code which is GOA.
CDR 220
Type 4462
SER 25013340
Thanks in advance for your help!
Try 6487
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hi
Hope you can help, battery died and now need radio code for my 2000 carrera 2.
CDR 22
Type: 4467
Serial: 15045625
Thank you for your help in advance.
Try 9654
Hi
CDR 22
Type: 4467
Serial: 15045625
Try 9654
Thank you Loren I will try this afternoon
Hi
CDR 22
Type: 4467
Serial: 15045625
Try 9654
Tried 9654 but doesnt seem to work, could it be anything else?
Hi
CDR 22
Type: 4467
Serial: 15045625
Try 9654
Did you get the serial number using the method in the Lost Radio Code FAQ?
That is the only way to be sure what the radio software thinks is the serial number.
Please double check your serial number.
Hi
CDR 22
Type: 4467
Serial: 15045625
Try 9654
I have followed the instruction on the faq's as well as taking out the radio and copying down the details
CDR 220
BE 4467
SERIAL: 15045625
Have tried the code that you provided, but just returns to the code screen
Not sure if Im doing something wrong.
Very odd - the program I have works 99.9997 % of the time.
You can try two unit above and below the code I gave you (i.e. 9656 and 9652).
In some of these rare cases that works.
Hi Loren,
I am looking for the radio code for the following:
CDR 220
Type: 4462
Serial: Y5041584
Try 0387
Perfect, thanks!!
Getting ready to sell car and would appreciate getting my radio code for stock radio (crd 210)
Model BE 2282
S/N V5016877
Thank you for your help!
Model BE 2282
S/N V5016877
Try 3038
