I had to disconnect the battery to replace the ignition switch and now my 1999 Boxster needs the code entered and I don't have it (pretty much the normal story).
Becker CR-210
R3297
SN: W5022855
Thanks very much for your help.
Try 6702
Unfortunately, that didn't work. I've tried numbers around that, but no luck. Will try some more numbers later.
Thanks for your effort.
Did you follow the instructions in the Lost Radio Code FAQ to get your serial number?
I am trying figure out what CR-210 owners are doing - because I have gotten many codes correctly and all of sudden they seem to be wrong.
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Becker CR-210
R3297
SN: W5022855
Try 6702
Yes, I followed the steps, but I can go through it again to make sure I didn't mistype anything.
Hi.. This is pretty much the same story changed the battery and the former owner did not include the code card with the rest of the manual and I have no radio code. any help would be greatly appreciated The following info applies
2001 Porsche Boxster
Radio: Becker 1 type 4462
serial# 15063185
here are some other #''s that came up on the display, don't know if they apply 24/99 CDP2081
Thanks again... spitball62 :)
serial# 15063185
Try 5494
Hello Loren, the battery of my 993 was reset, so I changed it today. Unfortunetly I lost my radio code card.
I would really appreciate it if you could help me to decode my radio.
Becker CDR-210
Type: 2896
Serial #: V5006747
1997 911 Carrera 4
Thanks a lot :thumbup:
Isabell
Becker CDR-210
Type: 2896
Serial #: V5006747
1997 911 Carrera 4
Isabell
Try 4829
Becker CDR-210
Type: 2896
Serial #: V5006747
1997 911 Carrera 4
Isabell
Try 4829
FANTASTIC Loren -Code works - you're MAGIC :-)
Thanks and all the best,
Isabell & Oliver
My battery died and the code from my dealer (based on the VIN) won't work.
Becker CDR-220
Model # 4362
Serial # X5019890
Thanks much!
Try 9491
I'm really hoping you can help me out. I have a 99 Boxster and let the battery die over the winter. Now I'm with everyone else here....no radio:(
I've got :
Becker
CDR-220
4462
W5010003
Thank you for any help you can offer
Sam
FYI - if you need your boxster radio code, the FIRST thing you should do is look under the front trunk hood, on the label opposite the hood badge, there is usually a hand written 4 digit code for the radio. Most dealers write it there, so check there first!
That's where I found mine and it worked!!
I've got :
Becker
CDR-220
4462
W5010003
Sam
Try 1024
Hi Loren,
Similar story as everyone else. dead battery, cant find the radio code.
Becker CDR-220
Model # 4467
Serial # X5017136
49/98
Thanks For Helping
Hi Loren,
Becker CDR-220
Model # 4467
Serial # X5017136
49/98
Thanks For Helping
Try 9547
