I'm needing the code to restart my radio in my '97 Boxter. The radio/cdr serial number is V5008478. Can anybody help me?
Also, and definitely secondary, I can't get the cd player to play; it accepts (and ejects) the cd but nothing else. Any clues?
If needed, the model # is R2896.
Thanks so much!
Try 7649
I tried it, but the 7 begins to flash after a few seconds and nothing else happens. Do I need to do anything other than punch in the numbers?
What is the exact model name on the front of the radio?
It should start with "PORSCHE xxx-xxx" where xxx-xxx is the model number.
It's a CDR 210
Please read the Lost Radio Code FAQ for the procedure.
OK! By accident, I got it. The code number worked, but only after hitting the "station up" button - which isn't in the FAQ info - so now, all is well! Thanks so much.
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Thank you so very much such a quick response you are great again Chris and I thank you!!!
My serial number is X5031540 type 4462. 48/98 asap on vacation with my brother please and thank you.
Try 1035
I would like the code for the Siemens PCM unit out of my 2001 996 TT.
MLFB: 5WK 78015.
Serial No.: PO8150113038/01.
MLFB: 5WK 78015.
Please read the Lost Radio Code FAQ....
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi lost the code to my CDR-220 radio.
It says Becker 1, type 4462, seri 25013521, cd CDP2081, 24/99
Thanks in advance!!!
Hi i have a 1999 porsche boxster lost radio code after removing battery please help.
Cdr220
Ser# X5018868
Type 4462
Tnx in advance
Cdr220
Ser# X5018868
Type 4462
Tnx in advance
Try 9505
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CR21
type BE 2180
serial w5009543
Thanks for your help  :)
Hello,
Becker CR21
type BE 2180
serial w5009543
Try 1564
Hi all. Just purchased a 1999 996.
Much thanks in advance for code.
See below.
Sn. W5008942
Becker 1
Cdr220
Type 4462
30/98
Try 3682
See below.
Sn. W5008942
Becker 1
Cdr220
Type 4462
30/98
Try 3682
Thanks Loren, this worked.appreciate the timely response. Definitely worth a donation to the site. Will send. Thanks!!
