Thanks Loren. I was meaning to try it over the weekend and let you know if it has worked or not, but didn't get a chance. Will prob next have a moment next weekend. Thanks in advance.
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
I had my car worked at a shop and they disconnected the battery and now my stereo doesn't work.  My stereo is a Becker?Siemen's Navigation System.  Any help with the code or codes, please?  Any help would be highly appreciated.  Thanks...
It's a Becker 2582
Serial Number #15008512
Siemen's Serial # PO8040065836/03
Hello,
It's a Becker 2582
Please read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Dear Loren
I hope the below works out, as i suppose it wont.
Thank you in advance
All the best
Thank you so much Loren for doing this.
My dad is going nuts trying to fix it.
Becker 1 Model 4462
Serial # 25015104
Try 9571
It worked! Thanks again!
Hi
I have a Becker BE6612 35046372
"How to get your radio serial number?
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
99 Boxster was fitted with IMS Solution - battery disconnect lost radio.
Becker CDR-220
Type: 4462
Serial:Y5045475
thanks in advance!
Hi.  Thank you so much in advance for any help.
2000 Boxster - 3rd owner, no code, battery disconnected
Becker CDR220
Type 4462
Ser Y5040927
Thanks again!
Becker CDR220
Type 4462
Ser Y5040927
Thanks again!
Try 4827
Loren, thank you for your reply regarding my radio code, however 1434 didn't work??  The information on my radio as follows:  Becker# CDR210, Model#EE2382, Serial # W5019267 ( the "9" may not be correct as it looks like a "9" without the bottom part of the number??  Any help would be greatly appreciated.   Many thanks, Jim
Loren, Went thru the steps for lost radio code and serial number came back as W5019267, however the model came back as 3297? None the less I went back out and tried the code again. After entering the code the number "1" was flashing, I pressed the arrow up button and it immediately went to a radio station. So all is good except now the CD player isn't working. Any idea's. Thanks so much for your help I wasn't aware of the Lost Radio Code page. Many thanks, Jim
Edited by Loren
Sent as an error report....
Did you use the procedure in the Lost Radio Code FAQ to get your serial number?
If you did not, then please do and report back here.
If you did and this code does not work then I am sorry - someone has changed something inside that radio.
Becker CDR220
Type 4462
Ser Y5040927
Thanks again!
Try 4827
It worked.  Thank you so much.
Loren, I replied to the above post but don't know if I was in the right place?  Really new to Renntech.  Anyway, I did go to the Lost Radio Code sight and went thru thr steps.  The radio code came back the same W5019267 howevcer, the model # came back as 3297??  Anyway I tried setting the code again and noticed mthat after entering the code the "1`" was flashing so I pressed the right arrow up key and it turned on and went to a radio station.  So all is well except now the CD player dosen't work now??  Thanks for all the help really appreciated, Jim
