  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hey loren, New porsche owner here. I hope you can help me. The radio is locked and the model is 4462 and serial is 15002167 thank you
Hi I've just signed up. I have just bought a 993 and after having a new battery I don't have the code for radio Becker CDR-22 holding down the tp button gives the following info
4467 type
X5020223 serial no
24/99
00
Can anybody help?
Many thanks
Mark
Nottingham UK
Try 2537
Hello Loren,
I have a 2001 Boxster S and and hoping you help with the the radio code:  CDR 220 / Model No:  BE 4462 / Serial No:  15064688
Thank you,
JDM
Hello Loren,
Thank you,
JDM
Try 4737
hello... Becker Traffic Pro "navisys"
S/N: 15000664
Thanks!!
Is this a Porsche Traffic Pro?
If not, I can not help you. Sorry.
Yes it's in a 996 C4S. Porsche branded unit.
Edited by dublove3030
S/N: 15000664
Thanks!!
For Traffic Pro with 6 presets try 42325
Hello, i´ve lost my Radio Codes for PCM1. Typ IDIS, Model No BE2580 Serial Y5012921
and the 2nd is Siemens MLFB: 5WK 78000A Serial PO800092759/03
can you help me please?
Best regards
996sample
Best regards
996sample
If you would have read the Lost Radio Code - FAQ -- Read This FIRST then you would have read...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
S/N: 15000664
Thanks!!
This worked great! Thanks!!
Hi, Loren,
I've gotten lots of good info from RennTech and Thank You, for that.
I had the battery replaced in my 2001 Porsche Boxster and need a code to try.
It's a Type 4462, Model CD-R 220
Ser # 5052484
Luckily I read the Forum first and saw how to get the serial # without removing the radio.
Thanx in advance.
