  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
The previous deck had a disc playing issue so I return it and now I need another code for CDR-220 model BE 4462   SN. Y5045171   Please
Try 0932
HI  I have a CDR 220 S# 15002800
Thank you in advance for your help
kmh
kmh
Try 2678
Thank you!  It worked.  I had no idea about this issue until the battery was disconnected for another issue.
Thanks Again!
Hi just found this page, hope it works.
I have a CDR220
Serial # 25012995
Thanks in advance
Kris
I have a CDR220
Serial # 25012995
Thanks in advance
Kris
Try 5091
Thank you so much, worked perfect.
Was just about to input info into a pay site, thanks again.
Hi Loren, new to this thread but can already see how much help you provide other members. I have a 2000 Carrera:
CDR-220
Type 4462
CDP2081
S/N: Y5051698
Called the dealer and was told the code is 8396 based off the VIN but it won't take. The code on my card is 8467 but that also won't take. Any help would be greatly appreciated.
Thanks in advance!
CDR-220
Type 4462
CDP2081
S/N: Y5051698
Thanks in advance!
Did you use the procedure in the Lost Radio Code FAQ to get your actual serial number?
If so then try 8467 again.
CDR-220
Type 4462
CDP2081
S/N: Y5051698
Thanks in advance!
Hi, just tried the 8467 code again and it wouldn't accept it. I tried locating the serial number via FAQ page and the only other numbers that come up when i turn the dial besides 4462 and CDP2081 are "24/99" and "GAL1 00". Is there an alternate code possibly from the one (8396) I received from the dealer? Thanks again...
Hello!
   Sorry to bother you. Could you please help me retrieve my radio code?
   Model: CR-220
   Becker 1
   Series: 25010870
   24/99
   CDP2081
   Abe.
CDR-220
Type 4462
CDP2081
S/N: Y5051698
Thanks in advance!
 I know the VIN isn't usually helpful but I just wanted to provide you with it just in case.  VIN: WP0CA2991YS654478.  Thanks again.
It appears i am not the only one to find myself in this nightmare , lost code for 2000 boxter  becker cdr 220 type 4462 ser# Y5038811  can anyone help ?   thanks
Try 5465
Try 5465
that was correct , thankyou so much , your a life saver...
How about for my 2001 Boxster
CDR 220
Serial # Y5021303
Type 4362
I retrieved it once from the dealer already last year and wrote it down on a piece of paper, which I mistakenly gave away with the service records to my Vanagon camper when I sold it last summer. Doh! This time the numbers going under the hood with a sharpie
CDR 220
Serial # Y5021303
Type 4362
Try 6571
You da man! I typed in that number and was greeted by the sounds of "Sultans of Swing" coming out of my speakers. I can't thank you enough, the dealer is 30 miles of gridlock away.
Hi Loren, after a bit of downtime my 993's CR-210 (R2095) lost its code. May I ask you to try your code gen for SN [ 55001147 ] ?
​Thank you very much,
R
R
Try 4570
