  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Loren, worked perfectly. Was tied up in traffic and what was a bit more than 30 minutes, request for the code came back up. Presets were still there!
Thanks again.
Rick
Hi folks, excited to have just joined the club with a 996 Arena Red Cab! Could anyone help me with the radio code?
Model: CDR-210
SN: W5024942
Thanks in advance!
Model: CDR-210
SN: W5024942
Thanks in advance!
Try 2107
4 minutes ago, Loren said:
Try 2107
Thanks for the quick reply, unfortunately no luck on the code. I'll try contacting Becker or the dealer on Monday.
Did you follow the instructions in the Lost Radio Code FAQ to get your correct serial number?
I believe so, I pressed 8 and 0 and then got the number which appeared after "Serial N".
If you copied the serial number correctly then it should work.
Only other time I have seen it not work was when the radio had a prior repair by a 3rd party.
Hi. I went to a Porsche dealership today and even they couldn't help me. Hopefully someone here can.
Model:  CDR-220
SN:  X5025381
Model:  CDR-220
SN:  X5025381
Try 6939
Don't often use my radio or CD player. Just to show how often I actually turn it on, it was 3 months ago the battery died and I had to replace it.  I recently took a 2 hour trip and decided to try out the radio and CD player and that's when I realized I needed a code. Prior to the battery going dead it did work because I put some CD's in the remote changer and tried it out. Anyhow, I have the CDR-220 and finally obtained my serial number which is - Y5051542, model 4462. It is a 2001 Boxster S. Any suggestions short of going to the dealer to get a code would be appreciated.
Try 1051
I also need help
Type:4362
Serial number: 15005 162
Thank you!
Sent from my SM-G935V using Tapatalk
32 minutes ago, eth2 said:
I also need help
Type:4362
Thank you!
Try 0850
Hi, this radio is PCM1 996.642.105.02
MLFB : 5WK7801
Serial : PO8010011207/02
SW3.67
I need code.
Thanks.
MLFB : 5WK7801
SW3.67
I need code.
Thanks.
From the Lost Radio Code FAQ...
" Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC. "
4 minutes ago, florida miles said:
Hi there lost my radio code sorry loren for e-mailing you directly. I'm a newbie and just getting used to this forum. Just bought a 2000 boxster and found no radio code! Bummer.   The unit is a becker cdr220.
Model 4462
Serial y5040147
Thanks for any help in advance.
Try 8354
Hello
i can't find my radio card code. Had to get a new battery. Could you please help me?
2000 Porsche Boxster
CR220 Becker
BE 4362
W 5003060
45 minutes ago, Trina said:
Hello
CR220 Becker
BE 4362
W 5003060
Try 9095
HI, usual story, new battery, no radio code
Becker traffic radio - BE7820
Serial # 55081499
any help you could offer would be greatly appreciated, thanks
