12 hours ago, Butch T said:
I am hoping someone can help me.  I have a 2001 Porsche Boxster.  Like many on this forum, when I replaced the battery, the radio stopped working unless I punched in a 4 digit code.  I need help to figure out just what that code might be.  The radio is model CDR 220
Serial # y5052932
Type 4462
Thank you
Try 0903
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
11 hours ago, Trina said:
Thank you, Loren. My code didn't work. I again followed the directions from FYI. Now I think I have have the correct info.
2000 Porsche boxster
CPR 2081
4462 15000612 24/99
Again thank you for your support.
Try 4385
Hello Loren,
I have a 2001 C4 coupe and the number of the cards for navigation and radio are not working.
Could you please help me? I tried
I have 2 different number and blocked both :(
Model: BE 2580
SN:55150128
And another serial number:
SN: P08030205822/04
Many thanks in advance.
Regards,
Raul
Edited by Shattheman
You obviously did not read the Lost Radio Code FAQ...
Quote
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC.
20 minutes ago, Shattheman said:
Sorry, now... yes, I have read it. Is there any way to recover it?
Looking for radio code for my 2000 boxster s
CDR220
SERIAL NO. X5038446
BECKER 4462
ANY HELP
THANKS
Greetings!
Like pretty much everyone else, I replaced the battery on my 2001 Boxster and now need the radio code. So glad to find this forum!
CDR-220 / Becker 4462
Ser #: Y5051410
Thank you for the help!
7 minutes ago, SwervinMervyn said:
Greetings!
Ser #: Y5051410
Try 4596
Hello, like most had  to replace my battery and have no idea where the code card is.
2001 Boxster S
CR-22
Y5023430
Thank you very much.
Hi just replace the alternator and do not have the radio code. can you help?
model 4362,  serial 15001555,    24/99
Thank you
2002cars
2001 Boxster S
CR-22
Y5023430
Try 0792
Thank you
2002cars
Try 0165
I have replaced battery in a newly purchased Porsche Boxster S reg VU03PNJ Radio is CDR22 can you help?
Serial number is 25008878 !!
