  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
I have the serial number for the Porsche CD-2 radio. On the back metal panel, the following is inscribed:
S/NO PO CD-2 A 03 13943
B 0 03 13943 A
Hope this may be helpful in getting a code number, or a start on one at least!!
Thanks again for your help.
Gary Knox
Edited by Gary Knox
Loren,
B 0 03 13943 A
Gary Knox
Try 0799
I really need help with this code can anyone work it out for me please?
Its a Porsche series Becker head unit
Serial V5001456
Model BE 2380
Style CR-31
It has a 4 digit code.
My code was 4964 but now that doesn't work?
If anyone can help? Please!
Edited by mariuzzz
Serial V5001456
Model BE 2380
Style CR-31
Try 4962
or
4960
Loren,
B 0 03 13943 A
Gary Knox
Try 0799
Loren,
0799 will not work, as this radio only has 6 buttons, with digits 1 through 6. Any other suggestions (it is either a Blaupunkt or Alpine radio, I understand).
Gary Knox
Loren,
B 0 03 13943 A
Gary Knox
Try 0799
Loren,
Gary Knox
Sorry, I have tried the decoders I have and the only one that will accept that serial number gives 0799.
Sorry.
Loren,
B 0 03 13943 A
Gary Knox
Try 0799
Loren,
Gary Knox
Sorry.
Loren,
THANKS anyway, I appreciate your effort. I'll try other searches.
Gary Knox
Thanks for the help Loren (and the patience!). I contacted my dealer today and the code on mine ended up being only one digit out instead of the 2 per the FAQ, not sure if this info is of use to anyone else.
Regards
Martin
good afternoon Loren. I need some Radio Code assistance. I replaced my starter motor this weekend and disconnected the battery. Here is my info
1999 C4 - Brian Mohr
VIN WPOAA2997XS624228
Becker 1
4462
W5006410
30/98
gal 1 (whatever that is)
Danke!
Becker 1
4462
W5006410
30/98
Danke!
Try 6980
or
6978
Becker 1
4462
W5006410
30/98
Danke!
Try 6980
or
6978
hmmm...i tried both and on the 3rd try it went into WAIT mode. Is this in lock mode now? Do i need to disconnect the battery again?
brian
Sorry to re-post Loren..but the codes 6978 and 6980 did not work. Radio is unlocked now after driving to work. Any other possible codes to try? TIA
Becker 1
4462
W5006410
30/98
never mind....i went up a few digits and found the right one! Thanks for the help!
brian
Edited by bmohr
thanks loren, the codes did not work , i even tried codes ranging from 9651 to 9655, needless to say i got the WAIT message, any other suggestions??
Serial V5001456
Model BE 2380
Style CR-31
Loren... last code don't work. :o(((
Based on the process of elimination I have almost 2 dozen codes from past posts. 3 every hour will take me too long and give me too many grey hair before I get the right code.
Can someone help me out with the right codes?
Type - 4462
Seriral - 25012341
24/99
Shawn
Type - 4462
Seriral - 25012341
24/99
Shawn
The codes posted above not for your serial number radio - so they won't work.
Try 6684
or
6682
Hi Loren,
After many combinations codes I use "Lost Radio Code - FAQ". The step was make for CR-210 and now I have new information:
R 2596
V 5001456
This information was from Radio, but on my RADIO CODE CARD I have another information (BE 2380 V 5001456). I dont understant why i dont have the same info???
Thank you,
Mariuz
Hi Loren,
R 2596
V 5001456
Thank you,
Mariuz
Your radio was likely replaced and the new card was lost.
Try 4962
or
4960
