  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
6 minutes ago, Loren said:
Try 1964
That worked.  Thank you very much, Loren.
Bill
3 hours ago, JP. said:
Loren,
I have been searching all over the internet, and spoken with two different dealers who seem to have no clue as to how to get my recently replaced CDR-24/wBose (purchased on Ebay) to work beyond the Porsche Protect screen. I found your instructions online.
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
Thanks for that!
I am still a little unsure as to what to tell them they need to do to reprogram the DME. They don't seem to know.  Do they need to program the new radios serial number into the DME?  Do they need a code?
If you know; can you give me a step by step overview of the reprograming, and the information that they'll need to reprogram the DME (and radio if needed.) I am taking the car in to get another key programmed next week, I'm hoping with the right information I can get this done at the same time. Thanks!
This is my first Porsche (absolutely loving it!) and while I eventually may upgrade the radio; for now, I'd like to get the CDR-24 working correctly.
Only a shop with a Porsche PIWIS tool can make the radio to car match.
It requires reading out the old radio and then reading in the new radio -- IPAS codes are required.
You will need to find a shop or dealer to perform this change.
I'm new here, and notice that radio codes can be provided if it's been lost.
My Becker 220 serial no is: Y5039630
Can anyone help out?
Thanx,  Vic
49 minutes ago, CaptVic said:
Thanx,  Vic
Try 5854
I have a 2002 boxster, radio reads "wait". Will keeping key on for an hour enable code to then be entered? I do not have code, radio is cdr-220, serial #25012346, 24/99, does anyone have code?
thank you
3 hours ago, bbrundle said:
Please help with radio code
Type 4462
24/99
Serial 15009249
gal 1 00
What happened to the different radio (and code) I gave you in March 2017?
thank you
Try 6725
4 hours ago, cherylfentress123 said:
Hi, lost code. Ser # w5009518. Can you help me with radio code for model. 4462. CDR220
Sent from my LGLS775 using Tapatalk
Try 7879
I just bought an older Boxster and want to put in an aux cable, and I don't have the radio code.
CDR220
Radio serial is x5021962
Thanks for the help!
Edited by imsora
CDR220
Try 4917
34 minutes ago, SuncoastBoxster said:
Need the code, please.  I've tried them all and none are working. 1999 Boxster, CDR 210. Serial number W5023261
thanks!
Back on December 3, 2016 I gave you the code 8686 and you said that worked. If it does perhaps you should write it down somewhere?
Hi. Need code for my cdr 21 becker Porsche 911 996 1998 model (don't know if this is essential info...)
Got the following from the display of the radio :
Serial no : V5011202
Ver : R 1097
Sufficient info ?
Ver : R 1097
Sufficient info ?
Try 8594
