  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Just bought a 2001 boxster S and didn't have the code, could you help?
Cr-220
Type 4362
Serial : Y5023832
24/99
Edited by Turbo-Sim
Cr-220
Type 4362
Serial : Y5023832
24/99
Try 2754
Hey Guys,
I bought a CDR 220 on Ebay for my 1987 Porsche 928S4 and need an unlock code.  The only serial number I can find is a number etched in mirror image.  The number is 3300/1277073.  Can anyone help?
Many thanks,
Brian
5 minutes ago, Brian24 said:
Hey Guys,
Many thanks,
Brian
You can get the correct serial number using the procedure in the Lost Radio Code FAQ.
Thanks Loren,
Because, in any forum, it's generally proper protocol to read the FAQ's before posting, I did read the FAQ's first.  As suggested in the FAQ, the CDR 220 was out of the car so I checked the stereo label for the number.  Since none of the other posts with a serial number had the same format as the number I found I went ahead and posted my query to see if the serial number was somehow the correct one (my mechanic thought that was the serial number).
Anyway, I got someone to bench the unit today and here are the results:
CDR-220
Type 4462
Serial Number: Y5039852
24/99
Thanks so much for the help,
Brian
42 minutes ago, Brian24 said:
Thanks Loren,
CDR-220
Type 4462
24/99
Brian
Try 5603
Hello! Just picked up this porsche and here to get some help please! Thanks in advance!!
Type 4362
Serial 25007500
24/99
Type 4362
Serial 25007500
24/99
Try 1096
hi i have a problem with a radio navi in my porsche boxster , i don't have an unlock code.
mode  BE2560
series X5020121
Porsche Boxster 986 1999'
thanks
mode  BE2560
series X5020121
thanks
You didn't read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
6 hours ago, razzomania said:
thanks. do i have to turn to porsche?
Yes, it must be a shop that has access to Porsche non-public build records.
Loren,
Many thanks and well done.  After the holiday I went back to the shop and brought the security code you posted.  It worked!  I got a great Porsche CDR 220 off of Ebay for next to nothing because no one else had the patience to figure out the code.  Thanks again.
Brian
Hello, I have a 98 boxster without a radio code, and need your help.
It's  a CDR 210
Version  R3297
Serial  V5017433
Thank you in advance,
Yuriy
It's  a CDR 210
Version  R3297
Serial  V5017433
Yuriy
Try 6975
21 minutes ago, Loren said:
Try 6975
Thank you very much!
Worked perfect, and your response was unbelievably fast!
You're awesome!
5 minutes ago, RUFGTR said:
Hello, I'm also part of the crew with a missing code. Thank You in advance.
CDR 220
Type 4462
Serial X5031571
Try 0283
Hi guys i got problems when i disconnect the battery my porsche radio is saying wait i have the serial num. Y5022869 the radio type is 4362. Is there anyways i can get the code? When this wait will be over thanks guys
Edited by Warrendavid
Try 6814
