  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
33 minutes ago, Abhishek Birjepatil said:
Please can someone help with the radio code..
replaced the battery and stuck at this.
Serial #: X5013166
thank you guys!
4
Try 4342
49 minutes ago, Will henriquez said:
I hope you can help me with the radio code for a Becker 1, serial number 15007830, type 4462
Try 8987
  • Thanks 1
Heyyyy, lost my radio code, not written anywhere maybe you could help my Radio is CDR-210
SERIAL number is:
BE2282W5023587
Any help would be appreciated.
Thank you!!
Hi. New Boxster owner here. The car sat for a while with a dead battery so I need a radio code.
CDR220
Becker1
4462
serial# 15064696
thanks,
Aaron
SERIAL number is:
BE2282W5023587
Thank you!!
Try 1031
CDR220
Becker1
4462
serial# 15064696
thanks,
Aaron
Try 4801
On 4/12/2019 at 11:51 PM, Loren said:
Try 1031
Thank you very much! It worked!
had a separate issue, radio turns off when car is running.
16 minutes ago, 4StringBass said:
Hello,
I've locked myself out changing the ignition switch if someone could please help ?
CDR-22
4467
serial: 15004793
24/99
Thank you!
Try 9161
