  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
I have a follow-up question.  As it turns out, my mechanic was using the wrong PIWIS! However, after switching to the correct PIWIS the system is asking for the code of the original radio.  I thought this is where the information we received from the dealership needs to be entered? Any advice how to proceed?
Thank you!
1 hour ago, Autobahn said:
Hi Loren,
Thank you!
I think is asks that if you say you are replacing - rather than installing new.
Try removing the radio -- then installing new.
Hi there, I just dug up my old CDR-200 serial 15008328.
Appreciate your help with the code.
Michael
Michael
Try 9280
Thank you very much. It works, what a shame I found the number written at the bottom of the unit - silly me.
1 hour ago, Michel1963 said:
Hi guys, biought a Boxter S 2000 and need the radio code.The Becker 1 220 serial number is Y5043554
Thank you
Michel
Try 8952
7 minutes ago, oldman40 said:
Thanks for any help
CDR-210
BE2282W5024479
Sticker on side is missing hope this is adequate info.
Try 1498
Hello,
Becker 1
Type: 4462
Ser: X5026359
48/98
I had a note next to my battery that said the radio code was 3812, although I assume the radio was switched prior to my purchase, since it doesn't work.
I would greatly appreciate an assist on this.
Edited by Derek Hughes
2 hours ago, Derek Hughes said:
Hello,
Becker 1
Type: 4462
Ser: X5026359
48/98
Try 2989
1 hour ago, Mattboxster said:
Hi, help please. Looking for the code of a 2000 Boxster S Radio.
Becker CDR 220
serial: y5035253
thanks
Matt
Try 8746
  • Thanks 1
