Hi Loren - Firstly many thanks for providing this service.
CDR-220
Becker 1
Type 4462
Serial#Y5040862
Cheers Cam
Edited by Cameron Arnott
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
5 hours ago, Cameron Arnott said:
Hi Lauren - Firstly many thanks for providing this service.
CDR-220
Becker 1
Type 4462
Serial#Y5040862
Cheers Cam
Try 0723
Hey Loren,
Changed my battery out in my 2001 boxster and now need the radio codes
type 4462
ser num 15062312
thanks in advance.
Ted
2 hours ago, Ted Park said:
Hey Loren,
type 4462
ser num 15062312
thanks in advance.
Ted
Try 6453
  • Like 1
Hola, tengo el mismo problema. Desconecté la batería y ahora me pide la radio el código pero no lo tengo- ¿Alguien puede ayudarme?
Número de serie:
BE4760
X5005086
¡Muchas gracias!
Número de serie:
BE4760
X5005086
¡Muchas gracias!
Tratar 9427
Hola Loren, mi radio solo tiene hasta el número 7.
Además me pide 5 dígitos
Lo siento, no vi que fuera un Porsche Traffic Pro.
Tratar 13425
Hi Loren,
I would appreciate any assistance you can provide.   I replaced the car battery and alas the radio needs a code; unfortunately I can't locate it.  It is a Becker CDR-210 model 2282 serial # V5017243; thank you again for your help.
3 hours ago, Blue Box said:
Hi Loren,
Try 4702
4 hours ago, Loren said:
Try 4702
Hi, thank you for the code unfortunately  it didn't unlock the radio.  I tried 4700 thru 4722.  Any chance there is an alternate code?  Thanks.
Did you use the procedure in the Lost Radio Code FAQ  to get the correct serial number (in the display)?
If not, please do so and re-submit the correct serial number.
Greetings Loren
I'd be very happy if you could offer me the code for:
CDR220
Model BE 6625
SeriL: 15001336
Happy Porsche'ing,
Pedro
11 hours ago, Travis Bolton said:
Would appreciate if you could supply the code for my CDR-210 Model R3297
SN W5024341
Thanks in advance!
-Travis
Try 4325
1 hour ago, ppbon said:
Greetings Loren
CDR220
Model BE 6625
SeriL: 15001336
Happy Porsche'ing,
Pedro
Try 6835
Please help me 99 Boxster
Becker - w5005135 serial number
CR220
I’ll absolutely donate !!!
my battery died today and I was stuck on the side of the road . Good now after roadside came out and replaced the batter but I have a 4 hour drive with no radio 😞
Edited by Sky Borg
CR220
Try 0634
Hi Loren, I had pulled the radio to get it off the label.  I did try the Lost Radio Code FAQ procedure (thank you, that is much easier than pulling the unit).  The procedure did yield the same serial number as the label (thankfully).  So long story short, I tried the 4702 code again and for some reason it took it on the first try today...everything works.  Thank you, thank you thank you.
