  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I can’t recall my radio code.  Any help would be great!  Thank you
Becker
C220
Type 4462
Serial number 15086415
Edited by AdamHelmer
My first post to RennTech.  I recently acquired a project boxster which of course came with the radio locked and no code anywhere.  It's a Becker CDR 220, model BE 6625, serial # 25014216.
Thanks in advance!
Becker
C220
Type 4462
Try 7021
Thanks in advance!
Try 5056
1 hour ago, 123ibrahima said:
Dear Loren,
Appreciate your assistance with code for my radio
CR 220
BE 4362
Serial No. X5019256
Best regards
Try 1346
9 minutes ago, nate_sweetcars said:
The radio is wanting a 5 digit code it says?
You did not say this was a Traffic Pro...
Try 63636
Hi, new to Renntech forum. I just picked up a 1999 911 and can't locate the radio code. Can anyone assist? it's a Becker CR-210 - model R-3297 - serial # V5007790. Thanks in advance!
Try 4983
1 hour ago, Loren said:
What (exactly) is the radio model number?
The card that is in with the owners manual reads CDC-3 11096648. Not sure if that is the radio model number/radio code or not.
CDC is Compact Disc Changer.
I need the radio serial number.
2 hours ago, ouisiek said:
Thanks but unfortunately that didn't work.  Any other suggestions?
Did you use the Lost Radio Code FAQ procedure to get your serial number?
If not then please follow the procedure and re-post. If you did then chances are your radio has not been repaired by Becker but has been repaired by some 3rd party. In that case I can not help you.
