2 hours ago, VinnyO said:
Hello, I just got a 2001 Porsche Boxer handed down to me that’s been sitting for quite a while. I finally got it started and I have lost the radio code. if someone could help that would be amazing. Thank you
CDR-220
Becker 1
type 4462
# Y5046578
24/99
Try 5494
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren i have a 2000 Carrera 4 and have just had a new battery this losing my code for the stereo it's a CDR 22 see y5027853 I hope you can help. Thanks
Try 9071
23 hours ago, VinnyO said:
Looks like I had one digit in the SN wrong. Y5046538
Thank you so much, I really appreciate it!!
Hi There,
I just bought a 2000 Porsche Boxster (my very first Porsche) and the Radio is locked out.
It is a 220 Model Radio, Type 4462, Serial # Y5035876
Hoping that someone can help.
38 minutes ago, Type-A-Hippie said:
Hi There,
Try 4320
Hi, im having the same issue. Disconnected the battery and need the radio code.
Dealership provided 4745 but its not working.
1999 911 Carrera Cabriolet
CDR 210
R3297
W5024689
Please help!!!!!!!
CDR 210
R3297
W5024689
Please help!!!!!!!
4745 should work if that is the correct serial number.
Did you get that serial number using the method in the Lost Radio Code FAQ?
If not, please do so.
If you did then chances are that your radio has been repaired by someone other than Becker. If that is the case I can not help you. Sorry.
  • Thanks 1
I just bought a 1998 Porsche Boxster. Radio version CR-210. Would you please help to pull the code for my radio? Thank you in advance.
Serial number: V5008227
Model number: R3297
9 hours ago, Duy Nguyen said:
Model number: R3297
Try 1304
  • Thanks 1
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type BE 4462
serial # X5028909
Thanks for your help, much appreciated.
2 hours ago, Rebra said:
Hello,
Becker CDR 220
type BE 4462
serial # X5028909
Try 3418
Hi Loren
Please can you assist me with radio pin:
CDR-220, Type 4462, Serial: X5023393
Thanks in advance
3 hours ago, Clide said:
Hi Loren
Thanks in advance
Try 0496
