Hello -
Had some work done and now also in need of my radio code. Thanks in advance for any help that can be provided!
I have a 2002 996 Carrera 4S
It is a CR-220
Becker 1
Serial Number: 15003323
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
2 hours ago, Mike Smyklo said:
Hello -
It is a CR-220
Becker 1
Try 2767
11 minutes ago, tecate04 said:
Hello new porsche owner and I am in need of the radio code for my 2000 boxster s
Serial X5032432
Thanks in advance
Try 4582
Hi I have a 2001 996
It has the CDR 220
serial (update this is the wrong number… will look up again and update!)
registered as a 2001 but serial says 09/2000
I've been through two batteries and never gotten this radio to work! Any help would be great Appreciated.
Edited by MCalbear
Hi at all! For my fathers car I need the code from the cdr-22. He lost the code and after the battery went down it stops working without code.
Type 4467
Serial Y5024776
24/99
Thank you!
It has the CDR 220
serial s620746
Try 2626
Type 4467
Serial Y5024776
24/99
Thank you!
Try 9025
I need the radio and sat nav codes for a Becker Idis PCM1
Serial numbers
Becker - BE2580 Y5034690
Siemens - PO8030075456/03
Serial numbers
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
99 911 carrera 4 cabrio - Need radio code help please. Thx in advance!
CDR-220
Becker
CDP2081
Type 4462
Ser X5035860
CDR-220
Becker
CDP2081
Type 4462
Ser X5035860
Try 3092
10 hours ago, CabrioArtie said:
Hi Loren,
New car for me, but no radio code.
Radio Model CR-210 (BE2182)
Serial Number - T5000742
Thank you
Try 2594
1 hour ago, Tillys said:
Same issue, here's my info:
Type: CDR 220
Model: BE4462
Serial: Y5040399
Thanks for your help. Much appreciated.
Try 4698
