  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
20 hours ago, MikHei said:
Hi' I bought my 966 2000 with a bad battery and lost the code to the radio
a CDR22
Becker 1
type 4467
ser Y5023879
can anyone please help!
Mika
Try 6704
  • Like 1
Hello
911 from 2000.
PCM unit
Typ IDIS
Model BE2580
Serial Y5050129
12volt EC102
SIEMENS serial PO80301330100/03
Can someone please help me?
thank you in advance
10 hours ago, Mihais said:
Hello
911 from 2000.
PCM unit
Typ IDIS
Model BE2580
Serial Y5050129
12volt EC102
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
1 hour ago, Rancher1957 said:
I need a radio code for 98 Boxster.  Becker CDR-210.
Serial # W5020336
other numbers. BE2282 and R3297.
Thank you for helping me.
Try 0610
0610 did not work. The first 0 just starts to blink again.
Are you sure your serial number is correct?
The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
Just had the battery disconnected on my 2002 911 Carrera 4 and am now in need of my radio code. Any help would be greatly appreciated!
CR220
Type: 4362
Serial No : 15004999
Thank you!
Haley
CR220
Type: 4362
Thank you!
Haley
Try 5147
On 7/9/2025 at 12:14 PM, jambaby78 said:
Hello, I need the code for my Porsche CDR-220 radio.
Model: BE 4462
S/N: X5029909
Thank you
Hi, do you have a code for this
Please give me the code for a Porsche 911 996 radio from 2000. I bought the radio and the owner didn't give me the code.
Just bought my first Porsche!  Previous owner changed the battery, but didn't have the code.
CDR 220
Becker 1
Type: 4462
Serial: Y5034837
Dave
That is not a radio that is a PCM.
CDR 220
Becker 1
Type: 4462
Serial: Y5034837
Dave
Try 3098
  • Like 1
Good afternoon everyone,
Im the second owner of a 1999 boxster. The manual is missing and im looking for a radio code.
Radio CDR-220
Type 4462
Serial X5021377
Thanks in advance for any help.
Radio CDR-220
Type 4462
Serial X5021377
Try 0748
