  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi, I just purchased a 1999 Boxster tiptronic where the radio does not work. The seller told me that as soon as he replaced the battery, the radio stopped working. At any rate, I would greatly appreciate you helping me with the code.
Model: 1999 Boxster Tiptronic
Radio: CR-210
PR Version: R 3297
Serial # W5011414
I thank you in advance,
Daniel
Try 4626
or
4624
If you have not already read this please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Radio: CR-210
PR Version: R 3297
Serial # W5011414
Daniel
Try 4626
or
4624
Thank you very much! Worked great! Cheers, Daniel
I just bought this car and need to replace the alternator. We need to install the code when I put it back together
· Model year - 2002
· Model/Engine: Boxster 2.7
· Transmission type: 5 speed
· Interior color: black
· Country specific information: US
Any help you could provide would be great. Thanks
· Model year - 2002
Please read this and follow the instructions...
Loren:
BE 4462
Ser # Y5051665
(Strange that code card that came with car, 2000 Boxster, when bought used from dealer in 2004, shows different serial number, thus useless code.)
I would have gone loony had I not been able to use your instructions to get actual ser. #. Much obliged
Thanks.
RR
Loren:
BE 4462
Ser # Y5051665
Thanks.
RR
Try 8203
or
8201
Loren:
BE 4462
Ser # Y5051665
Thanks.
RR
Try 8203
or
8201
Thanks 8203 worked
After changing battery (which is why I needed code) I found Lighter port is also not working but fuse is fine even though I changed it. Don't care about lighter but do need port for aux power and charging battery over winter. Where would I post query?
Again, thanks.
RR
Loren:
BE 4462
Ser # Y5051665
Thanks.
RR
Try 8203
or
8201
Thanks 8203 worked
Again, thanks.
RR
Please choose the forum with your model number.
Hello, I have just acquired a Carrera 996 and the seller doesn't have the radioCD code.
Model: CDR220
Type: 4467
Ser: x50 13660
Thanks!!
Edited by aalbel
I just bought a used 2001 Boxster and the 'code' message appears on the radio. I was able to get the SN:
Y5047065
It's a CDR-220.
type: 4462
24/99
Glen
Edited by gborkowski
Hello,
my friend needs to know code from his radio. He gave me these information:
becker 1
4467
24/99
gal : 00
ser: Y5036206
CDP2081
Let me know, if you can help. Thank you
Pavel
