My 2009 Cayenne T shows Chassis System Fault and the whole front end drops after 1 min of driving. When I start the vehicle, the compressor comes on and the front raises to the right height. If I just sit there in park while its running , the compressor comes on very other minute but does it lose the height and the ride level stays up. I did get a fault code of 1708 which is the the vehicle level sensor.
Does this make sense or could it be multiple factors like an ECU or relay or air leak?
THanks
