Just got my first 911 in December. A 2002 C2 6-speed with PSM.
I love it!!!
It is in need of some tires though. It came with BBS 7.5-18 50 fronts & 10-18 65 rears.
I’m looking at the Potenza Sport 225/40-18 & 285/35-18. I get a really good discount on Bridgestone’s & Firestones.
Will the 285/35-18 mess with the electronics or the handling?
Is it worth paying twice as much for PS4S’s that are the right size?
I had non N spec PS4S’ on my 03 C4S and was having an issue with the PSM. Put N spec PS2’s on and the issue went away. If you are just putting around town, you probably won’t have any issues. I drive my car pretty hard.
Not at all although to your consideration your actual speed will be tiny higher as your rears have a 1/2" bigger diameter as your rears are 35 sidewall ratio instead of 30 required and the speed is calculated from your rear ABS tires RPM. The factory rim sizes for you are: 8-18 and 11-18 so your BBS are a little off and the sidewall ratio for the rears is 30 not 35 so your rears are a bit thicker because of that making it a little butt-up. But for the PSM it is no matter at all.
My 2003 C2 Cabrio arrived at a time 2 years ago with 295 35/ZR18 because the seller bastards put in ExtremeContact DWS which is not having the size for 295/18 of the 30 sidewall ratio. So at some point in 2023 I got a set of 17" factory rims as 17" is the default rim size for the 996.2 and 18" is optional which is for MY2003 the factory had put all 18" rims option (which is on your hood label) so with 17"-s with the proper sizes PS2-s (205 50/17 and 255 40/17) the ride is a bit nicer/softer and the pup is horizontal as the proper size tires makes the pup absolutely horizontal no but-up but for PSM doesn't matter at all as it takes the input from your gas pedal position, PRMs, acceleration sensor, which one is the gear-in, and the ABS.
Edited by alex222
