99 Boxster Base.  On both sides of the convertible framework there is a curved guide in which a pin rides. I have attached a photo from my car and what i think is the correct diagram with part numbers from the manual.  On my car the pin grinds on the lower surface of the guide for about an inch or so.  If you look carefully at the photo you may can see the paint rubbed off the guide just under the pin where I've circled things. It sounds horrible but doesn't seem to affect operation.  I think the pin is steel and the guide is Aluminum they are parts 24 and 25 on the diagram.
Maybe I've got the top adjusted wrong? - it opens and closes OK.
I can lube it but the pin is rubbing pretty hard on the guide so it pushes the lube right out.  Anyone ever replace those guides? Is that a thing one does?  Anyone ever filed down that guide right there to relieve the pressure from the pin?
Other one looks same. The pin in the guide moves with the bow under the rear window. It's like the pin is being pushed or pulled down as it begins to travel. Just for a bit so it rubs on the lower surface of the guide then it rises enough to be centered in the Guide and not rub.
Edited by rlordjr
I asked because the bottom of the are where the pin is to slide looks like it cracked due to some abnormal stress in the picture.   Compare it to the other side. .
Mike, I think that cracking you see is the rubbing of the pin on the guide.  But I've looked at more pictures and in this one you can see the other side of this part.  You'll see the metal spring that pushes up on the pin at both ends of its travel.  I'm thinking either the spring is weak/broken or maybe the pin is rocking in its middle - the spring on the outside is now pushing down the inside end of the pin.  Maybe the bushing the pin goes through has disintegrated.  If you look at my original picture, just above the tip of the arrow you can see the glint of the spring on the other side.
