Stupid little clip
So I put in the B&M SSK and lowered the car this weekend(way to easy) and I broke to little plastic clips that hold the wire away from the strut. This wire goes from one side of the brake caliper to the other. Tried explaining it to my local p-shop but........ anyways it is a really small item but with out the part number I am up the creek. Any help would be greatly appreciated
01 C2 CAB
Front or rear? (or both?)
A picture would help too...
Ok maybe this will help. Look at this post http://www.renntech.org/forums/index.php?s...=2532&hl=shocks
Picture number 2 has a wire in a gromet on the strut. Right below that is my clip
That's the clip which helps route the brake wear sensor wire around the strut to the caliper. It secures the sensor wire to one of the hard brake lines. I have broken one of those clips and also had a hard time getting a replacement from the dealer's parts counter. I don't seem to have any significant problems without the clip.
