Oil pump drain plug
There is a drain plug on the bottom of the oil pump. Mine was loose and some oil dripped out. I have since tightened the plug but I am concerned about it since the oil did not seem to be engine oil. Does anyone know if anything other than engine oil would be present in this area? If it is something other than engine oil, what kind of oil is it and where is the fill hole?
