While changing my Fuel Filter I broke on of the clips on Fwd Coolant Support (7) 996.106.475.91
On the PET CD. Im having trouble identifying the correct part number in need to replace.
Illistration 105-05 Model 996 Year 99
The Long Coolant lines that run through the tunnel have to support brackets that hold the tubes in place running through the tunnel, The aft set of brakets that support the Fuel Filter are OK but the set FWD (7) in the tunnel tha holds the two Long HARD cooling lines and small line is cliped between these Pet shows Line (4) and (5) being held by Supports (6 & 7) and I think (7) is what I need but there is also a part number (-17) might be the part I need as well. Not sure hope this is enough info to go on.
Dennis :help:
